Quadzilla Downloads
I have forwarded these XZT+ tunes for Second Gen Cummins: Standard Tunes_1000_1001_1003_1004_2000_2001_2002_2003_2004_2005_2006_2007_2008_2009_2010_2011Beta tunes:Beta1Beta1000Beta2000Comp3000 (very aggressive fuel, unpublished tune)I don't think I got all the tunes & don't have the full descriptions except as follows:XZT+ Tuning File Updates:File Name: XZT+_1000 UPDATED: 3/12/2008 Models: DXZ29802 Software Version: 20080128 Feature Code Enabled: XZT+1000 Features:NEW Factory Tuning file that all XZT+ Modules are shipped withAfter updating with this file you will now have a feature code that is not enabled from the factoryEliminates any and all surging on both automatic and standard transmission trucksFile Name: XZT+_2000 UPDATED: 3/12/2008 Models: DXZ29802 Software Version: 20080128 Feature Code Enabled: XZT+2000 Features:NEW Aggressive Tuning file that all XZT+ Modules are shipped withConsiderably more aggressive than previous aggressive file Surging and Shuddering resolved with this tune on most vehiclesBETA1XZT+ Tuning File Updates:File Name: XZT+_BETA1 UPDATED: 11/17/2008Models: DXZ29802 Software Version: 8007111 Feature Code Enabled: XZTBETA1 Features:Beta file that makes fueling more aggressive and helps eliminate surging related to old way of doing fueling and timingBETAFile Name: XZT+1000 UPDATED: 06/06/2008Software Version: 80020606 Feature Code Enabled: XZT+1000 Features:Revised Tuning for more smoother powerNote: For these tunes the .NET framework ver 3.5 is required before these updates will work properly. Download ver 3.5 for free here: .NET framework ver 3.5These new updates dated 6/6/08 and newer will work on all XP and Vista machines and laptops.BETAFile Name: XZT+2000 UPDATED: 06/06/2008Software Version: 80020606 Feature Code Enabled: XZT+2000 Features:Same as 2000 tuning with more aggressive throttle responseNote: For these tunes the .NET framework ver 3.5 is required before these updates will work properly. Download ver 3.5 for free here: .NET framework ver 3.5These new updates dated 6/6/08 and newer will work on all XP and Vista machines and laptops.
I found this not to long ago, hope you guys can use it. I have the 3000 tune and running it right now. It surges at 1400-1500 rpm with my combination of parts. I'm changing back to either beta 1000 or 2000 next.post-11421-138698199849_thumb.png
I found this not to long ago, hope you guys can use it. I have the 3000 tune and running it right now. It surges at 1400-1500 rpm with my combination of parts. I'm changing back to either beta 1000 or 2000 next. [ATTACH=CONFIG]5287[/ATTACH]
I use the 2010 tune on my 2nd gen and it works great. No surging or other problems.
HI;I'm new to this community. I have a 2002, Ram 2500, 5.9 Cummins with a Quadzilla XZT+ running the Beta 1 code. It's run fine for several years. Recently, while driving, the engine simply quit. I pulled over to the side, shut the key off, waited 10 seconds and then started it up. It was as if nothing was ever wrong. It's run fine ever since. No dead peddle, no lack of power, starts after just one turn of the engine; cold or warm. The only difference is the high idle function of the XZT+ no longer functions. All else is the same. Power, mileage, etc.I ran the codes and came up with a 1691. I recently installed a Blue Chip VP44 so I attributed the problem to the XZT+. So I went to the Quadzilla site to download the latest codes. Well, we know the story there.I read here that you folks have those codes available for download. How do I go about doing that from this website?Thanks for the help.Paul G.
  • 2 months later...
just bought a 1999 dodge ram 2500 from a guy and he told me about your site. My quadzilla xzt+ has the high idle still on it and when it kicks in it will kill the truck, i have to turn the key off and let it sit to let it reset. After that it works fine. which code should i upgrade to to fix this? What program is used to update it too since quadzilla when out of business? When i plug it into my computer windows does not get a driver for it.
My saved files says for XP & Vista. Running a newer system (7) might require running in an earlier mode. I have an XP laptop, so maybe that will run it. Also might require having the actual devise plugged into the computer.
  • 5 months later...
  • 3 weeks later...
