mixing oil in tank...
- Replies 4
- Views 3.1k
Mopar1973Man 1 post
stodg73 1 post
dennhop 1 post
rancherman 1 post
I raided Wally world last week and bought every jug of 2 stroke they had. $12 and change/gallon.I just put new injectors in my 903, and I want the first sip of fuel to have the extra lube!So, here is my situation, This tractor has 2 saddle tanks, about 110 gallon each. They are connected at the bottom with a 2.5 inch pipe. My filler inlet is on one tank only, (same tank that pump draws from and returns to). I'll pour 2 gallons of wallys blue into the tank (it's about 3/4 full at this time)... and stir the crap out of it. I was thinking about getting a paint stirer chucked into my drill? The fuel cap is 4 inch, so getting something down in there shouldn't be a problem. Maybe even a piece of 2 inch wide flat steel (as a paddle to mix) Going with new filters too, so I should have a pretty decent chance of hitting my new injectors with plenty of slippery diesel!After this initial fill, just pouring the 2 stroke as I am filling should be good enough for mixing... Plus, the agitation from the return is huge!
