Question on truing my brake rotors
- Replies 9
- Views 2k
Mopar1973Man 1 post
Wild and Free 1 post
Lone Watie 1 post
Gamble 1 post
I wrote earlier this week about my oscillation/uneven braking. The manual states the following concerning turning the rotors on a lathe. Can someone please tell me what this means? Is it something a machine shop will know when I go in there and tell them what I need, and, does this imply that the hub needs to with the rotor for turning? Thanks.
The lathe must machine both sides of the rotor simultaneously with dual cutter heads. Equipment capable of machining only one side at a time may produce a tapered rotor. A hub mounted on-vehicle lathe is recommended. This type of lathe trues the rotor to the vehicles hub/bearing.
