coast not working
The problem I'm having is with the cruise ,on and I come to a hill it holds speed but coming down it will gain not correct . So I push the coast button and will not slow down I've also tried it on the flat and coast will not work .The accel botton and cancel does work . I'm think coast button is bad or the cruise servo? I have change the vaccum lines and I have no leaks thanks jim Posted Image 1999 dodge ram 2500 quad cab 2wd 5.9 cummins stock 5 speed
since you are a manual tranny you have no servo. The cruise is controlled by the ECM. If all the other controls are working i would think the coast switch is bad or become disconnected. The clock spring harnes could also be bad. Hopefully someone else knows how to test it. It should not be that hard to do. You have to remove the air bag from the steering wheel to get at it. The bolts holding it are on the back of the steering wheel. This is very important; DISCONNECT YOUR BATTERIES FOR AT LEAST 30 MINUTES PRIOR TO REMOVING ANY AIR BAG TO ALLOW THE CAPACITORS TO DISCHARGE. You need to read about that one in the FSM.
It might only be the 01 and 02 manual that does not have the servo. My 02 does not have one. It is controlled by the ECM. An easy way to tell is when you set the cruise does the pedal move down or just look under the hood. My pedal stays all the way up when the cruise is set and the tps goes to 0%.
