Getting Diagnostic Codes not related to my trucks standard equipment
Hi All,
I recently bought this truck. I checked for error codes to see if there was anything that required my attention. I got 4 codes...
P0753 - 3-4 shift solenoid / trans relay circuit
P0713 - trans temp sensor voltage too high
P1763 - governor pressure sensor volts too high
P1687 - no cluster bus message
I am confused as to why i am getting p0753 because i have a 5 spd manual in the truck. Is this normal any insight on this and any of the other codes would be helpful. Thanks.
I assume that both the 5spd and 4spd auto use the same computer and instrument cluster circuitry? If so can i alter the programming so it knows it has a manual and it doesn't throw the codes for an auto that isn't there?
