For Sale - 2006 Dodge Ram 2500- Flatbed for long box bed Winch bumper Flat Bed for Long Box 3rd generation Cummins Tootlbox are included with key I have a flatbed for 3rd Generation dodge Cummins. This flatbed comes with a gooseneck hitch already in the bed. The winch bumper is part of the set. Tootlbox have a key to lock and unlock all box a single key. There is rust starting and electrical will have to be sorted out on your own.
Price: $1,000.00
Hey guys, new to the forum. I have a '98 Dodge Ram 2500 Cummins 5.9L 24valve automatic 2 wheel drive 3:55 rear axle ratio. I have done literally everything I could possibly do to my truck to improve the mpg. Yet, I cannot seem to get anything over 15-16 mpg in the city and hwy can vary from 16-22 mpg. Current mods are afe cold air intake, airdog 100gph pump, rv275 injectors, smarty tuner, 4" straight exhaust, IAT fooler, scanguage 2, tires are toyo m-55 245-75-16 filled to 80 psi. The truck would get 15 mpg city/hwy bone stock with a 3" exhaust however when the fuel pressure was tested I was told that it was at 9psi at idle. I'm wondering if its done damage to the already weak vp44 I seem to see other 4x4 trucks getting 18 mpg city as for me doesn't matter what smarty setting I am on or how much timing I give it if I really baby the heck out of it I can maybe manage to pull 16 possibly 17 city hwy mix. I'm planning on changing my diff oil to amsoil 75-90 same weight as I have in there now just hoping the amsoil will help also running 5-30 amsoil in the motor with a bypass. What could be causing the mileage to be so low? Truck shows no signs of starving for fuel I have the airdog set at 18psi now but if damage has already been done not knowing how long its been running 9psi from the PO is there any test I can do without having to pull the whole pump out?
