Bd rad box
Anybody run one? I have an 02. And was told I have torque management. And the rad box eliminates that...? Any ideas?
  • Replies 7
  • Views 6.2k
My buddy ran one on his 02 at the drag strip. I believe it will kill all your gauges in the cluster while its on but it works great.
Better have a fully built tranny with all Billet shafts as well, things get super radical really fast once you kill the torque management.
Damn. Really?
Torque Management hold till about 20-25 MPH before releasing and then the full power comes on. So if you think you have power then you'll be surprised of the power after a Rad Box. But there is a down side to it if you use a Rad Box then the instrument cluster is canceled out and doesn't function correctly.
Damn. Really?
Really...........I never ran one, I had one but never installed it, I drag raced with my smarty stacked with an edge Hot comp the smarty reduces the torque management but does not eliminate it and I snapped my stock output shaft in my tranny.
Output ? Launching ?
Yes and Yes.:evilgrin: The time trial run a few minutes before the run it broke was an 1/8th mile run at 7.8 seconds can't remember the speed. Shaft snapped right at launch and I never left the line.
