Traack bar is destroyed again, 3rd one in 8 months. Anyone know of a 3rd gen track bar kit that will work with a 5 inch lift? All I can find are for "up to a 3 inch lift"
Good grief! LOL
Not bad for 91,000 miles. 3 transmissions, 4 steering boxes and needing a fourth, 2 broken leaves in the left rear spring, 2 sets of bushings in the front link arms, the 3 trackbars, and 2 front driveshafts. On a lighter note I do have just under 43,000 miles on the tires listed in my sig.
And I thought I had problems... Sent from my SPH-L710 using Tapatalk 2
I also forgot about the rear spider gears, diff bearings and wheel bearings I replaced. Sent from my DROID BIONIC using Tapatalk 2
  • 3 weeks later...
Okay, you gotta help me here. I have alot of trouble understanding why in the world a person wants a truck lifted sooo high? I'm not saying 5" lift is big or small, as I have no idea how that really looks in person. But to me, there comes a point where lifting it anymore and it just does not look right. My logic is, yes, it is a good thing to have some lift. But anymore what good are you doing? The lowest area on the truck is the differential housing. If you can't go over something without hitting that then whats the point? :shrug:Bigger tires to raise the whole truck is a diff. story...
Okay, you gotta help me here. I have alot of trouble understanding why in the world a person wants a truck lifted sooo high? I'm not saying 5" lift is big or small, as I have no idea how that really looks in person. But to me, there comes a point where lifting it anymore and it just does not look right. My logic is, yes, it is a good thing to have some lift. But anymore what good are you doing? The lowest area on the truck is the differential housing. If you can't go over something without hitting that then whats the point? :shrug: Bigger tires to raise the whole truck is a diff. story...
I actually bought it with the lift already installed or i probably wouldn't have done anything but a leveling kit. The big plus to the lift and tire combo i have is that i don't need to run a raised hitch to pull a tow behind deck over trailer. Everyone else i know with a stock height truck has to run a raised hitch to get the trailer even close to level. Sent from my DROID BIONIC using Tapatalk 2
Only thing left to do now on the front end is bearings, ball joints, tie rods, and control arm bushings (again). Oh, almost forgot the axle seals alsoSent from my DROID BIONIC using Tapatalk 2
