Dead pedal, codes, and bad news from tests - please help
- Replies 9
- Views 2.4k
howboutdemphillies 4 posts
dripley 2 posts
Mopar1973Man 1 post
diesel4life 1 post
Hello, I'd like to thank you all for already teaching me so much. This time I'm in quite the bind it seems.My problem started about 6 months ago with what came to be a small surging while maintaining moderate speed ~ 40 mph. I thought it was my foot shaking a bit and thought little of it. 2 weeks ago the surging was terrible and started in the morning while leaving for work. I limped home idling in granny gear up hill the whole way.Original code was 0122, so I replaced the APPS with one of Timbo's. Problem not solved. I also replaced MAP sensor from Cummins and ordered the adapter from Geno's. Checked the wires and grounds and things appear good. Finished installing the gauges just today and they appear to work ( big thanks to mopar1973man for the boost location). I went with the Vulcan line and it went in smooth on the fuel gauge. But I digress...Current codes are 1693, 0236, 1475, and 0122. The truck starts and idles fine but acceleration is SLOW, like 2 seconds to get to 2000 rpm, parked in neutral. I can wind it up as far as I want but can never hear the turbo spool while revving parked in front of the house. The gas pedal seems like it is either "on" or "off" and I cannot maintain a rpm level. When I try to maintain, I fall back to idle with the customary, at least for me, hiccup at return to idle. Fuel pressure is 9 psi at idle. Power is gone - can't get out of second without stalling. Both fuel pumps were replaced in 2007 and have about 40k on them.I failed 2 tests while running through the code diagnostics (thanks a lot for those - very helpful) in that for 0236 #9, my resistance is 36k ohm, much more than the 1000 ohms max, and for 1475 #3 my voltage is 5.04, less than the 5.2 threshold.It looks like I need a new ECM unless anyone out there can think of something else to check or if there is a bit of wiggle room on the DVOM. I appreciate your time in this long post. Please let me know.Phil
