Suspension help
I should have put some smileys in that. I did not take it that way at all. Its all about how you want your truck to look. If you want your truck level while empty, go for it. A lot of folks like them that way. I personally like the forward rake while empty and a level stance while loaded. Mine came new with the same blocks in the rear you apparently have. If you put 33's on there it will still set level. Remove the front spacers and it will have the forward rake to it.
I'm glad you didn't take it that way the way it came out wrong and I just got the truck about 4 months ago cause I've always wanted a diesel (if I had the choice I would go back because of fuel and maintance costs) its more of a daily driver I don't haul anything but a couple 4 wheelers from time to time.
:lol: Thats where the trouble begins! Before you know it, you will be finding an excuse to use it more!
I also am running 35's with 3.55's. With the 6 speed I do ok. I also like running over 70 and still be around 1700-1800 rpm's. I just have a 2.5in level kit up front and stock in back. Looks almost exactly level when unloaded.
Yes my truck runs about the same but its not near as quick as trucks with 4.10s and my egt get so high trying to accelerate in the highway with no load on it.
