New to me 98.5 2500 Issues
- Replies 29
- Views 6k
Mopar1973Man 8 posts
MorePower 8 posts
gassernomore 5 posts
guesswho512 2 posts
Hi All, I recently purchased a 4WD 2500 24v 5.9 with 115K miles. No problems at all for the first 800 miles. Twice since then, the engine has stumbled. Cruising at about 35mph, fully warmed up, with about half a tank of fuel, it just fell on its face for about a half a second, and then picked itself up like nothing ever happened. Any thoughts? I drained some clean fuel from the fuel/water separater, no water. There was a wire dangling that I re-connected to the filter housing. I think it was for the water in fuel sensor. That was about 100 miles ago. Today, the ABS and BRAKE lights come on and stay on. Gauges all look normal, and the brakes seem to work fine. Probably unrelated, but pressure builds up in the fuel tank. Is that normal? I was going to check fuel pressure at the filter. My fuel pressure test gauge goes up to 100 psi and says DO NOT USE ON DIESEL OR MULTIFUEL ENGINES. Why? Possible gasoline contamination of fuel? Who knows, I'll buy a new gauge, any suggestions? Thanks,Jay
