Map and IAT Sensor cleaning. Is this right?
- Replies 6
- Views 4.1k
Texas CTD 2 posts
kedlin88 2 posts
Mopar1973Man 1 post
dripley 1 post
Ok, so I decided to clean my MAP and IAT sensor today on the 99 24valve I just bought. There were no check engine lights, and it runs and drives good. I just figured it wouldn't hurt to clean them. This is the first time I have ever done this. I took out the MAP Sensor, it was pretty clean, but I did some work on it. Then I take out the IAT sensor, which is below the MAP at the bottom of the block??The two sensors look the same except for the electrical connections. I did some reading on other threads before I did this and everything I seen, the IAT has like a white plastic tube extruding from the sensor. The black is the MAP, and the tan was from the IAT sensor location? Is this right? Do some of the IAT sensors not have the white piece? Thanks,
