98 5.9 24 valve
You sure it is turning over fast enough? That sounds more like it is cranking slow than anything else. Do you have a fuel pressure gauge on your truck? If so what does it read while cranking?
He said it cranks over fine.  Is there a chance some wire somewhere is corroded and the starter pulls the voltage down enough to keep whatever from turning on?  Hence why pull starting it fixes the issue since the starter isn't pulling the voltage down.   :shrug:
Guest
This topic is now closed to further replies.
