Boost What Boost?
Gamble
Pretty simple question here.
I am going to put together a BLDC.  (boost leak detection contraption) as I feel I have a small leak in the upper boost pressures (only seeing about 24psi)  What do you use, how did you build it and what parts are used to build it?
That's what I would expect. I am sure there are many possible factors, I may have an injector or two getting tired, may have a boost leak. Not sure but as always the mopar family helps narrow things down. Thanks guys. Any other input is appreciated.
Edited by Gamble
This why I typically suggest the compression test and pop testing of the injectors together. Because if your going to yank the injectors out to pop test you might as well test the cylinder health too by running the compression test too. Now you know the cylinder health and the injector health in one pass with two tests.
