ExxonMobil has announced that NASCAR began this month using Mobil 1 Advanced Fuel Economy and Mobil Delvac 1 LE 5W-30 engine oil in its 65-truck fleet as part of the sport’s Race to Green initiative.
Tony Stewart, driver of the No. 14 Mobil 1 and Bass Pro Shops Chevrolet SS, introduced the the new oils by ceremoniously topping off his a 2014 Chevrolet SS with Mobil 1 on April 4, prior to the start of the Duck Commander 500 Sprint Cup Series race that weekend.
Michael Lynch, VP of Green Innovation for NASCAR, joined Stewart in topping off one of the NASCAR hauler trucks with Mobil Delvac 1 LE 5W-30.
  • Replies 37
  • Views 4.1k
Your worry is unfounded , if Delo 5W30 or Delvac 5W30 can meet Cummins ISX M-11 Detroits DD-15 & Mack Volvo standards  why would it not be good in your engine ? All Sae oils are backward compatible , at least until the new PC-11 comes in to use.
Really??? My engine was designed at a time when the oils form the American Petroleum Institute were rated as a CH-3 now current oils are a rating of CI-4 and CJ-4 that were designed to be used in 2002 and newer engines using EGR systems. These newer oils are designed to be better and more robust in the newer and much tighter tolerance engines. Under these new designs they are still wanting diesel engines to run a formulated 15w-40 oil. Not a 5w-30 oil. As for me the "Factory Recommended" oil to be used in my truck was a CJ-3 not this new CJ & CI - 4 oil on the market. I don't have an EGR system nor do i like the CJ-4 and CI-4 specs for ultra low sulfur diesel engines.  As for me my worries I'll stick to the 15w-40 for know.
Oddly , after reviewing API specs I find no CH3 or CJ3 , are you sure on your spec ?
my thought is if it meets CES20081 run it. While some may be afraid of lighter oils I welcome them.
CH4 specs were released in 1998 to meet the new emmissions criteria. That being said, it's been discontinued for several years now. CI4 oil is becoming harder to find and will eventually be phased out as well.
Unless your running AM$OIL or a dino CI4 oil, your likely running CJ4 oil. Viscosity has nothing to do with the specs, it is  about soot retention and ashless formulas to prevent the dpf in 07.5 and up trucks from plugging.
Wow. Kind of hard to believe that just by changing motor oil weights it would make that much of a difference. I went from a 15w40 Dino to a 5w40 full synthetic and did not notice any difference.
Because there isn't any difference. 40 weight is 40 weight. The 5w and 15w are you cold weight characteristics. So you start-up characteristics changed a little bit but the full heated characteristics remained the same of 40 weight. You would have to change to 10w-30 or 5w-20 to see changes. It the second number you want to drop.
But once again there is no one around me that sells a CI-4 or CJ-4 oil in any other weight than 15w-40 period. All the 10w-30 and 5w-20 is all "S" rated oils which are not designed for our engines.
There are several manufacturers that are making 5w40 and 10w30 diesel engine oil with the CJ4 specs. 10w30 is actually the recommended viscosity on some newer light duty diesel engines now days.
Please could you list these oil brand names down so I can see if I can get these oil locally?
5W40 is a very common viscosity and you should be able to get some form of it locally. I know my local NAPA carries Mobile 1, Valvoline Premium Blue, and Rotella T6. There are many others as well, including Amsoil and Schaeffers which I use in the wifes VW TDI, the ones I listed are very common and should be available at most any auto parts chain or tractor supply or farm and fleet store. These of course are synthetics (or at a minimum synthetic blend), I don't know of anybody that makes a 5w40 dino oil.
As for the 10w30, Mobil DELVAC 1300, Valvoline, Castro Hypuron, AM$SOIL, Schaeffers, just to name a few. There are many others out there.
The brands I see most
Mystik
Citgo
Mobil & Chevron
Shell all in the 10w30
I just was in a farm store in W. Missouri the had a huge display of the New Delvac 1 LE 5W30. Price was not bad either 18.99 per Gal.
Have you tried ?
CONRAD & BISCHOFF, INC.
2251 North Holmes
Idaho Falls
ID 83401
800-869-6844
They are listed on Mobil's website as a stocking distributor for Delvac 1 products.
Edited by skellyman
I was in Sam's club today and was suprized to see Delvac 1 LE 5w30 available , price was not bad either. $16.99 in gallons
Are you running a 30w engine oil?
I'm a little hesitant to run 30w oil on an older diesel engine. I know they are recommended in some newer engines, with tighter bearing tolerances and such.
Yes a 10W30 diesel engine oil , per the owners manual 99 2500 it is a acceptable oil.
I had a 95 v10 that I ran 10w30 when I bought it (2008 with 175k miles) and it used about 2 quarts every 1500 miles. I decided to try Rotella 15w40 and the consumption went down to about 2 quarts in 3000 miles and never increased before I sold it this year at 230k miles. It did not help the mileage and it did make crank slower when it was below freezing. As a old mechanic I was always told if a engine used to much oil to go to a heavier weight oil will help.
:doh: I also get 30mpg with a stock 2001 auto. 14 mpg town + 16 mpg hwy = 30 mpg overall
