4 thing that will kill a VP44...
1. Fuel pressure too low. Suggested: 14-20 PSI this is for Bosch requirements of 70% return rate for proper cooling and lubing.
2. Fuel Lubricity score too high. Suggested: <450 HFRR all US diesel fuel scores in about ~520 HFRR considered poor by Bosch's standards. Be careful of the products you select because some actually make the score worse.
3. Excessive AC Noise. Suggested: <0.1 Volts AC measured at the alternator BATT stud.
4. Poor Fuel filtration. Suggested: Using 2 fuel filters. Or even a good quality single filter with a 2-3 micron rating.
* footnote for #2 - A lot of products are either injector cleaner or cetane booster this is one product you need to try to avoid using because typically the higher the cetane the low BTU rating is of the diesel hence the MPG's fall then on top of it high cetane fuel in the summer tends increase injector noise.
You should never mix products together. Read over the SDS sheet and the chemicals. Then think of how those chemicals might react with the 2 cycle oil.
http://www.howeslube.com/MSDS_Sheets/US/Diesel_Treat_SDS_-_U.S.pdf
Item 2. Fuel Lubricity.  What product & quantity are you using?  I'd like to make sure I'm using the right stuff & correct amount.
Item 3. Excessive AC Noise. To check this can I simply use a multi meter set to AC volts?  Should I ground the multi meeter directly to the battery? or to the alternator housing?  Does it matter if checked at idle or should it be done at any certain rpm range?
Thanks!
Correcting the quote
Thanks!
Item 2 - 2 Cycle oil. 128:1 ratio. Or 1 ounce of oil for every 1 gallon of fuel.
Item 3 - Check the AC noise at the BATT terminal on the alternator and the passenger battery ground or alternator ground (case). No need for change of RPM's idle should show it.
