2001 auto, 18# boost
This turbo is weird. There is a steel tube between turbo compressor and the gate actuator. I have studied the turnbuckle fix and the J-Hook from bullydog that adds spring tension to the gate. Are there any more options? Will more boost help me at stock without investing in a tuner to add more fuel? I know I will need at least a boost fooler.
The HX has a bigger exhaust housing. It is either a 12 or 14cm where the HY has a 9cm housing. The hx was 98.5-02 on the manuals and 01-02 autos were the HY35. Someone correct me if I'm wrong!
Correct.
With no or little mods, the HY will spool quicker. As I said, I have the Adrenaline on mine & can run pretty clean with the HY turnbuckled.
$2.00-$4.00 for the turnbuckle & $30 or so for a boost fooler, or get a tuner that does boost fooling.
Ed
