- Replies 11
- Views 3.8k
dave110 5 posts
oldbeek 2 posts
rancherman 2 posts
JAG1 1 post
O.K. so I'm chasing a hard start issue and apparently a little air leak seems to be the kryptonite to the mighty Cummins. Everyone says replace sealing washers, connector tube O-rings and the return T. In my searching I've found many don't know where to get the parts and when they find out they come from Cummins they don't know the part numbers. I got on Cummins quick serve which I found difficult to navigate and finally found the parts and #'s, and added them to my cart. Trying to check out all I got was some Java bla,bla,bla message. I'm no IT guy and you should not have to be to use a website. I found out they have a central warehouse 50 mi. from me so I called them direct. 3 of the 6 numbers I gave off of Quickserve were no longer valid so we got that fixed. After 3 days waiting I called and it appears the CS guy lost my CC#. I reordered, and parts came next day. I was told I had to order the whole return T fitting to get the seals inside. The T fitting came with no seals. So I called and waited..........................and waited..........................and waited ect. and finally got someone and got cut off. This happened twice. After an hour on the phone I got it straightened out and will hopefully get the seals for the weekend which I set aside 2 weeks ago to hopefully fix this x0!@#$% truck. So to save the next guy the frustration I went through I am posting some part #'s. This should be pinned in my opinion but that's up to Mike.
12mm sealing washer-- 3963983
14mm sealing washer--3963988
return T fitting--3905353
seals for return T-- 3905351
crossover tube O-rings--3867043
VP 44 overflow valve-- 3941156
I hope no one ever has this air leak fiasco that leaves you pulling your hair out wondering what to do next, but in searching it is not uncommon at all.Hopefully one of these will fix my issue which I will report on in my other post. If and when you do experience this I hope these numbers will help ease the pain a little.
