Oil smoke
Well after leaving my truck parked for a couple of weeks now. I fire it up and now I can visibly see oil smoke just a puff at initial start up and gone. If its parked in the shop you can smell hang in the air. As for driving there is no oil smoke under normal driving conditions. Now this might be park of the last bout I ran the exhaust brake and would see it after a long down hill run. I'm starting to wonder if the valve seals are getting sloppy? There is no blow by.
  • Replies 47
  • Views 7.6k
Just a quick question, how much oil could one potentially lose through a worn out turbo? I am now going through about a quart every 600-800 miles. Its getting pretty bad. I know I have some play in the turbo shaft. Not enough to let it contact the housing yet but more than I would like. As far as I know the turbo has never been opened and I just crossed 235k miles on the truck.
short answer? Plenty!
If it (oil) winds up on the compressor side, that is where you get 'runaway' situation... The engine is getting enough 'fuel' from the oil vapor and is chugging along. When it pukes into the turbine side, it's blue smoke galore. Turbos have a seal on each side, Usually it's the HOT side that goes away first.. heat cooks em down faster there.
As seals get stiff, worn, or otherwise close to 'going south'.. a lot of times they'll only leak when pressure is gone. Upon repressurization, they'll snap back to attention.
Might be what's going on with Mikes here.
But now its not leaking/burning a drop of oil it still just how I filled it. Slightly over-filled.
Well I just picked up another commuter car finally so I can leave the truck sit for a while if I have to. Maybe I will pull the turbo off one of these weekends and put a kit in it. Thanks for the info rancherman!
well, new, clean oil revitalized the seals for now?? (if that's where it was going!)
I run about 2 quart every 5k but I only change my oil 8 to 10 k. I noramally starts to burn quart ever couple weeks at that point. I blow my turbo up last year. I was putting oil In it every week and I had was blue smoke on start up till it got warm. I lost my turbo pulling pass with trailer on. I am almost 350k right now after the turbo failed it stop burning it.
