VP44 advice needed
Also, the raptor is not pushing pressure like it used to be.  I can adjust it to where it will be pushing 19psi at idle and it will drop to around 12-13 just driving normal.  Would replacing the supply pump maybe rectify this situation or is it too little too late?
I had this very same thing happen with my old Raptor 100 pump. Finally it would heat up and after 30 minutes of driving the pressure just started dropping. Had to stop by the side of the road and let it cool for 15 minutes then it was good for another 30 minutes driving and made it home that way.
I finally called the factory in Missouri after this. As I was an "old time" customer with the lifetime warranty they made me a deal on a Air Dog 165 and its worked great ever since. Pressure at idle is 19-20 and WOT never below 17 so more than enough.
Edited by FlatTwin
