Vacuum Pump Oil Leak Driving Me Insane!
- Replies 16
- Views 9.2k
rlane547 5 posts
Mopar1973Man 4 posts
CUMMINSDIESELPWR 3 posts
joecool911 2 posts
Alright, need some help here before I take a sledgehammer to it. A few months ago I had to replace my power steering pump. I figured since I was going to pull the vacuum pump anyway, I might as well be on the safe side and clean, inspect, and replace the o-rings even though it wasn't leaking. I've now put three sets of o-rings on this pump and I'll be @#$%ed if it isn't leaking again. I make my living as a mechanic but I may need to think about a career change. The first two sets of o-rings were from Gould. A buddy had bought it but ended up selling the truck so he gave it me. I followed the instructions exactly and torqued everything to spec. First time, leaked between the retainer and housing. Second time, same scenario, but leaked from seal lip. This time, I'm not sure. I flipped it the bird, did a lot of cussing, and came in to ask you guys. Each time I have cleaned everything like I was doing surgery. There are no burrs, no wear marks, no dirt, nothing. Only difference I saw between seal kits is that the Gould kit seal fit tighter in the retainer compared to the Cummins. Any help greatly appreciated!
