order of reliability improvements/over heating
- Replies 38
- Views 8.1k
Dave3500 17 posts
CSM 10 posts
Mopar1973Man 5 posts
Hawkez 3 posts
Hi all,
There used to be an order for doing the step by step improvements on a VP44 truck, does that still exist? Bought a clean 2000, 2500 4x4 club cab & need that list for a reference. I will get an Air Dog Raptor & a Fuel Gauge. Also need a temp gauge for the Auto. Is that still the way to go?
So my 1st sort of concern. I was coming back from Canada pulling a 24' pontoon boat on a 28' trailer no worries until I got to the border, as we sat for an hour, wasn't that hot, drove about 200 miles w/o the A/C, my engine temp gauge started rising till about the 3/4 mark. So waiting in line I quickly raised the hood up to give a quick check & noticed that the A/C kicked on by itself & started cooling the engine, I noticed the condensation puddle under the truck along w a green antifreeze puddle in front under the radiator on the driverside. Don't think it was from the upper hose but maybe the bottom. I had to quickly close the hood & move the truck. As I moved there were no more green puddles, also the engine temp gauge was getting back to normal running temp.
So I have no leak at the moment. How did it heal itself? I'm keeping an eye on it. Anyone with a similiar situation. My 98 would idle all day at any outside temp & not change from the reg running temp.
What to do? The PO replaced the head gasket w better head studs only to find out it was one of the 22 soft plugs that had a leak.
Thanks,
Dave
