How can I Lower My Egt's
I'm trying to get the lower egts on my 99 dodge 24 valve nv4500. I have the banks monster ram, pusher 3.5 inch hot side inter-cooler hose, bhaf air filter, fass 95gph fuel pump, straight piped exhaust, edge ez tuning set on 2 setting. I am trying to get better fuel millage, i have never pulled anything with it. i travel at 65 to work and my egts are about 600 to 630, how can i get them lower, thanks
  • Replies 97
  • Views 20.9k
  • Yea 37's on 3.55 gives you an effective gear ratio of 3.00:1 out back.  You have to be doing 80 before you have enough RPMS in OD to get the 64mm turbo spinning at any real speed.     Regear
  • When you don't have the mechanical advantage of gearing the motor has to work harder to keep the tires rolling. This effect, combined with the reduced rpms of tall gearing makes for higher load at low
  • Is your EGT issue at cruise or WOT?   If it's at cruise going to a larger turbo will make your cruise EGT issue worse. If its at WOT then a larger turbo will lower your EGTs, to a point.
Slow down. Optimal MPG is had at around 55-60 MPH. Beyond that the numbers start to degrade as you travel faster.
Boost is going to be low and drive pressure is going to be low so intakes, coolers and pipes are not going to affect the EGT's nor the MPG's. At this point its all about speed since there is no boost pressure or drive pressure.
What kind of mileage are you getting?
There is more to consider than EGTs alone.
i would like to drive 55 its pretty hard to do. 20 mpg is about average
20 at 65 is nothing to complain about.
Exactly... 20-21 MPG is what I see at 65 MPH.
But it's true a 10 MPH drop will push it even higher. Typically if I hold back to 55 MPH I see a easy 24-25 MPG but pyrometer temps drop to about 500-550*F at 55 MPH.
don't these need to have a certain EGT to keep them clean? don't they start to collect carbon build up under a sustained EGT?
Unless you are towing heavy you will be hard pressed not to develop a carbon layer on the pistons.
600-630* isn't anything to worry about, why are you concerned about these temps?
Actually I could build carbon up with my light weight running. But towing I'm able to exceed 1,000*F fairly regular climbing grade and carbon will burn at 1,000*F plus.
exactly i get way good mpg at 55 and my egts are low thats what i want at 65mph is what i have at 55mph.
Im not worried about my egts i just notice when they get above 600 i loose 4-5 mph instantly. so saying that if i have my egts at 65 mph what they are at 55 mph, if i got my egts over 600 it would only be a small loss vs a big loss
The only way your going to do it is slam the truck to the ground and reduce all aerodynamic drag. Every thing above 55 MPH is about aerodynamic drag at that point.
EGTs are the byproduct. You could drop the EGTs with airflow stuff, maybe, and your mileage wouldn't change.
so bought all you can get out of it. Right?
Well this is my first post on this site, so here goes.
First off 20 MPG is great fuel economy for a 5.9. Could it be better sure but as it has been mentioned earlier in this thread 20 MPG is nothing to be worried about.
Your tuner may yield additional fuel economy on a lower or greater setting. Playing with the settings may help you net an additional 1-2 MPG.
Also if your running factory injectors having them POP tested and set at the Cummins spec of 310 BAR plus or minus 5 BAR can help too.
Using quality oils can also help with fuel economy but you may only gain 2%-5% at most. Propper tire inflation will of course help your fuel economy.
Secondly your EGT values are in the normal range. Myself personally I have larger injectors and a different nozzle type not used in the original ISB 235 engines and I usually sit around 650 or so at around 65 MPH. At 75 MPH I'm usually in the 725 area.
So just judging by what data you have shared I'd say your doing great.
There may be better tuners than what you have, but if mileage is your only goal it takes a long time to save money with a small mpg gain.
awesome thank you everyone been helpful
that thing needs to see 850-1000f degrees from time to time.. keeps the carbon cleaned out
Correction. Need to see above 1000*F to burn carbon off.
But that is 1000° on the piston right? So I would wager, based on fuel/rpms/timing/etc, that piston crown temps would exceed 1000° with EGT's in the manifold of less than 1000°. They don't last long thou.
It would be a cool, thou difficult, experiment to take several engines and run them all thru low load driving for a while and then see exactly what EGT's start cleaning the carbon out.
Either way I don't think it takes long to carbon back up, and a good 6 hour tow of 900-1200° should have the pistons all shiny :-)
Wash it out with water...
(Please don't do this it will do damage to a diesel... Just trying to be a bit funny)
