- Replies 23
- Views 3.8k
cbrew 8 posts
rburks 4 posts
Mopar1973Man 3 posts
Me78569 3 posts
Good Morning all,
well it seems like every 6 months or so this issue returns,
i just slayed that dragon last night and its really getting old. my battery clamps are not going to take much more of this before needing to replace them
so here is the low down on the recent findings,
the Ground on the primary battery has the acid build up, the other three did not.
the problem was only presenting itself at speed between 40 and 50 (in the past, this would happen at any speed above 40mph in OD)
i have a switch that i can use to kill my alternator (story for another time) so i killed it thinking it could be related to the alternator and the heat we been having. nope issue was still present, i know the alternator shutdown cause the voltage dropped to 12.8 volts
so what i did to fix the issue,
1) I cleaned the drity post, test drive, same issue.
2) cleaned the other three, in turn resetting the ECM etc. calibrated the apps, issue was gone
so with the alternator out of the system, what would else would be back feeding noise into the system.
i have concluded that cleaning the posts promote a clean power source, and reason the problem goes away.
blame it on the engineering side of me, i want to find the cause.
I know some have seen results with adding the filter, and i may end up breaking down and installing one, but something has to be behind this issue..
Thoughts?
Thanks.
