Brake/Park Brake Indicator
- Replies 8
- Views 2.2k
Mopar1973Man 2 posts
Hawkez 2 posts
Me78569 2 posts
dave110 1 post
My "brake" light
on the instrument cluster comes on from time to time. I never gave it much thought, because it was the only light illuminated. I figured it was the switch at the parking brake. Now...after reading the FSM, it appears this light can also be an indicator of a malfunction in the braking system. I did not know that. After reading, if there is a malfunction it is normally accompanied by a "ABS" indicator
. Like I said, I don't have that, but it appears that is because that light doesn't work. I went out and turned the key to on and all of the indicator lights come on except the ABS light.
The FSM says that this is a LED that is soldered to the board. So if this is the case, I guess I can't just swap that out with a functional bulb....that sucks
. Do normal code scanner read ABS faults or do I have to get something specific?
