Re-seal an outboard lower unit?
- Replies 5
- Views 2.9k
Wild and Free 1 post
AH64ID 1 post
joecool911 1 post
01cummins4ever 1 post
I know this doesn't fit exactly with RV's, but it's close.
I've got a 1975 Johnson 50 that leaks water into the lower unit. After a few trips the fluid is milky. I regularly remove the lower unit to change water pump. But how hard is it to replace the seals? I have a factory service manual coming from eBay. It's cool that I found one! There are 2 seals. One on the shaft going to the power head and one on the prop shaft.
I've always been frustrated by the fact that these older outboards don't have a pee stream to see that water is circulating. Kinda like old men. But I found a mod for that. Drill out the head for a $3 fitting, run some tubing to another $3 fitting in the lower power head case and you've got a pee stream. Both fittings on eBay. I'll need to remove the head to drill it, but that will allow for resurfacing anyway. Worst part is removing the 8 head bolts without breaking any off. Outboards get
A white film on the treads that make removing bolts risky.
