- Replies 9
- Views 3.6k
pepsi71ocean 4 posts
Vais01 2 posts
Mopar1973Man 1 post
cbrew 1 post
So I pulled the alternator out to swap the rectifier, and found the alternator brush pack garbage, so I pulled the old Napa alternator out and swapped the rectifier into it.
I installed the alternator into the truck and hooked the batteries up. Then I started it and checked AC voltage, got .025vac, then switched the volt meter to DC, and it read 12.25v. Puzzled I checked the idiot gauge and sure enough it wasn't charging.
I then pulled the old alternator out put it back in and now the truck is still not charging.
I took the charging lead off the alternator and it is .05v.
I haven't checked for codes, but I will when I locate my scan gauge 2.
Anyone have any ideas?
