- Replies 201
- Views 40.3k
Vais01 83 posts
Mopar1973Man 34 posts
dripley 26 posts
Me78569 14 posts
I have seen several dealerships void warranty for anything aftermarket. That said a K&N WILL VOID POWERTRAIN WARRANTY. Seen this more than a few times. If and when I do buy a new vehicle I will pu
The problem is not just buckling, but sealing properly. A small chunk of 4" exhaust pipe on the inside of the flange is the definition of "cheap insurance". An old tim
It's for guys like me that are always barely out of idle.
I currently am working with a manufacturer to have an additional BHAF filter option. This filter uses Donaldson's Powercore technology and has a capable flow rate of 1300 CFM while filtering the air down to a micron rating substantially better than stock.
I am currently in process doing heat soak and IAT temp checks and EGT checks at WOT runs, cruising, part throttle acceleration and transient boost speed from cruising to passing acceleration.
Next tank of diesel will be a fuel economy test to see if any improvement exists.
I will do my best to keep everyone up to speed.
