Posted October 11, 20159 yr My abs and brake light are one I am thinking a have a front sensor out. I wanted to make sure there wasn't a wire broken and I can't for the life of me even find them and I just missing them or does the wheel have to come off
October 11, 20159 yr The front ones come from the unit bearing and should be clipped to the brake line and up in to the engine bay. Just look for the flexible brake line. You dont have to take off the wheel.
October 11, 20159 yr looking from behind the right front wheel. My thumb is touching it. If you dont have the wire maybe you only have rear wheel ABS.
October 11, 20159 yr Author Did they all come with front sensor I took a picture not sure how to post it
October 11, 20159 yr Not all have 4 wheel abs. If you look at the lower right corner of where you post you will see "More Reply Options". click on that and you can up load them from your camera.
October 11, 20159 yr Owner My abs and brake light are one I am thinking a have a front sensor out. I wanted to make sure there wasn't a wire broken and I can't for the life of me even find them and I just missing them or does the wheel have to come off
October 11, 20159 yr Author Still cant figure out pictires but I was looks at your post and in one of the pictures the one with the air box off there is a plug and in yours it looks like that is where the abs plugs into and in my truck they're is nothing plugged in to it
October 11, 20159 yr Owner Just showing the cable that has to be disconnected. There is a plug near each shock tower.
October 11, 20159 yr Author That's the one nothing is plugged in they're where is it on the driver side
October 11, 20159 yr Author Ok I think I found it right by the abs module and there is nothing in that one also
October 11, 20159 yr Owner Sensors missing? There is a plug on both shock towers. The black cable should go down to the unit bearings.
October 11, 20159 yr Author Yup right next to both towers nothing is plugged into either of them if I could figure the picture thing out it would help. Did all trucks come with them
October 11, 20159 yr Owner Some where rear ABS only. But if you got the ABs pump and module under the hood then you should have them. As for the posting pictures... http://articles.mopar1973man.com/mopar1973man-com-site-information/478-adding-an-image-to-a-post-on-mopar1973man-com
October 11, 20159 yr Author Mine doesn't look that that though it's just a little black Blox on the side
October 11, 20159 yr Author Ok so I should only have the sensor on the rear pumpkin and one the photo part I don't have the attach file option
October 12, 20159 yr You can't attach a photo because I believe that is a paid member option. If you don't have wires coming off the front wheel bearings than it is rear wheel ABS only. I know when the rear sensor went out on my 99 I got both brake lights but the speedometer also quit working.
