I could really use some help. Back on 3-11-10. My friends truck a 2002 Dodge 2500 HO turbo diesel 2wd completely stock took a dump. Would start but under acceleration it would just dead pedal. pulled him home and the temp gauge was bouncing all over the place and the cruise light would blink on and off. He thought it was the IP and LP so he ordered the IP and a Fass DDRP LP. We installed it and it made no difference at all. I know we should have pulled the codes first but we didn't:banghead:. So we pulled the codesPCU p0122, p0500, p1693.ECU p0121, p0230, p1689, p0217, p1488, p0575, p0562, po237 I did some searching and found a post by mopar on 5-29-2009 that said Quote:Pretty simple really... P0121, P0122, or P0123 error codes are present with a dead pedal. A failing APPS always throws a code where a failing VP44 might throw a code and might not... I told my friend and since we had 2 of those codes (p0122, p0121) he ordered an APPS from timbo the next day. Later that day on my own post about this problem mopar wrote Don't bother with the APPS... Look at your codes... You got a mess of low volt codes that are not making sense...ECM is on the way out... I've seen this before... My friend decided to try the APPS first and it didn't make a difference:banghead:. So then he sent his ecm off to GOECM.com to be rebuilt. He got it back today and installed it and the truck runs exactly the same:banghead:.Now we are really puzzled:cookoo:. His dad had a code reader and they cleared the codes before installing the APPS. I had him pull the codes again tonight after installing the rebuilt ECM and this is what he got. pcu p0123, p1694, p1693ecu p0575,p0562, p1488, p0117, p0342, p0112, p0606, p1295Some of these codes are different that the original ones we got. Once again low voltage everywhere. 0606 ECM failure. We are not sure what to do next ? Mopar please do not take this post as a bash at you. I just did some searching at diesel garage and here and picked out pieces of your posts without taking all the info into consideration. We should have pulled the codes before the IP and LP replacement.(we would have seen the low voltages everywhere) We are ignorant. I should have waited before telling my friend it was the APPS (even though we had 2 of the codes for the APPS we had a bunch of low voltage codes pointing at the ECM) We are stupid. Now having the ecm rebuilt and still not working. We are puzzled. I still think we can fix this ourselves with a little help from ya'll. Hopefully someone can point us in the right direction and we can get his truck back on the road. Thank YouRob
