- Replies 32
- Views 6.6k
TFaoro 8 posts
CSM 6 posts
CTcummins24V 5 posts
The_Hammer 4 posts
Larger turbine has more weight, rotational mass, and requires more airflow to spin so longer spool time. Smaller turbine wheel builds more pressure VIA input CFM of exhaust so it will spo
Shut up, Tyler.
Some of us just don't have deep pockets for toyz like this.
So I installed a bd super b 57/65/14 (s300g) a couple weeks ago and have put a couple hundred miles on it so far. Towed a dump trailer this week put some good highway miles on it, it wasn't a huge improvement over my holset wh1c 58/60/14 non gated. Spool is a litter better, fuel economy is a little better, it whistles louder and pulls a little better. The biggest gain is the drop in egts, dropped a couple hundred degrees. I still like it and it is an improvement but not what I was hoping for. The 60mm cover and wheel on my wh1c lit faster and pulled harder...but surged like crazy, hence it being sold. I'll report back this weekend after I abuse the super b this weekend, now that it's broken in
Oh ya, install was a pain. The waste gate arm was hitting the oil drain tube, even after clocking the center section in every way. I had to heat the tube with a torch and used pliers to crimp it down about an 1/8". I still only have about a 1/16" of clearance. Then, the drain tube didn't line up with the tube on the block, so I had to cut the drain tube back and order 7/8" ID hose from CPP to make it line up right. That special 7/8" ID oil resistant hose is impossible to find locally and isn't cheap...
