Defrost and floor air only.
Well guys I just replaced my heater core and my air only comes out the defrost and floor vents. Any suggestions why? I'm about fed up and about ready to send it to the dealership.
  • Replies 9
  • Views 2.5k
I haven't had one of these dash boards apart in a while but it sounds like one of your selector doors is stuck or a vacuum line is off or broken.
Pretty much.
Did you reattach the selector tubes on the drivers side of the unit? Has like 5 different tubes for the selector switch.
Edited by gassernomore
7 hours ago, Buzzinhalfdozen said:
Found it. Main vacuum line broke. I replaced it and rerouted it through the driver side of the firewall after I found a diagram.
Could you paste a link or a upload attachment for that map...
There you go. Hope that helps in the future.
Now I've run into the famous blend door coupling failure. Any ideas where to get another one.
You are welcome. It was a good part with great instructions to install and index the door.
