Heated mirrors working?
- Replies 19
- Views 3.4k
dripley 7 posts
Mopar1973Man 5 posts
Direwolf 2 posts
Vais01 2 posts
Thex emblem on your dash switch will light up. If you don't have the switch, timer, and wiring for that switch your mirrors won't run.
All it has to do is keep the mirror above freezing to shed the ice. The freezers that we install in restaurants all have a heater in the door to keep the gaskets from freezing to the door frame. The u
This I have noticed. It also helps clear the fog.
It's getting cold and I'm wondering if my heated mirrors are working before it gets icy. I noticed the heated emblem on the mirror itself and was wondering if that is supposed to light up too when on? Most likely going to put some tow mirrors on, but want to check before diving into that project.
thanks
