No charge. Now over charging.
- Replies 9
- Views 2.2k
Popular Days
The alternator grounds thru the mounting bracket. My truck had some resistance on that ground because of the paint on the bracket so make sure a good ground there and make sure of the heavy ground cab
Try doing a voltage drop test. No more than .2v on the positive cables and .3v on the negative cables. Just today I had a car with a dead battery and low output (13.0v). I did the voltage drop test an
Ok guys here we go.
My truck is a 2000 2500 w/ 24v cummins and here is my problem. I bought the truck back in September 15 and has run like a top up until now. I am driving to work this morning and my voltage dropped out and dash light can on saying "check gauges". My immediate thought was ok I just lost the alternator no big deal. Pulled it off and went to Napa, had it tested before I bought a new one and surprisingly it tested OK. Bought a new one anyway for good measure and had it tested before I walked out of the store, also had both my batteries load tested while I was there and they check out.
Get back to work and throw the new alternator on, drive it for maybe 10 minutes and same thing as before. Volta drop out and I get the check gauges light. Ok I'm stumped. Do a little research and find out that it could possibly be the plug at the back of the alt because it looked a little sketchy to me or it could have been that the voltage regulator in the PCM took a dump. Look up the price of a new PCM vs doing a voltage regulator swap and decided to go back to Napa and pick one up and run it like the old days.
I followed Moparmans instructions to a tee and it seemed to work. Drove maybe and hour and a half and I'm watching my volts going up and down continuously until it spikes and I get another check gauges like only this time it's over charging.
I have checked all my grounds that I can find, I have check continuity between batteries and resistance etc. My question is before I spend 500 on a new PCM that my problem is the voltage regulator in the PCM. All my gauges work on the dash so it can't be the crank position sensor ( I think). Please if anyone has any other ideas or input please send its way. I have done everything that I am capable of doing to fix the problem short of replacing the PCM.
Thanks guys
