Looking for Staff Members
So from my research I've done so far, the 1693 code is just a code thrown, letting you know that there is a code present on one of the other computers right?
The 0500 code is a speed sensor and ABS issue, short version, the pcm(?) can't tell why or thinks that front and rear wheels are spinning at different speeds. The CEL only shows up when my key is turned on and the WTS light is on. Once the engine is running, the CEL is not back lit and the truck seems to run fine. Occasionally, I'll have first gear run a little longer then it seems it should, and I have a weird lock up thing happen in between 3rd lock up and 4th. I can expand on those if need be.
Other possible factors to cause this are the hypertech tuner that the PO had installed. I turned off the tune but did let it correct the speedo for the bigger tires. Could that be the reason its throwing the code? And why it's only showing the code during start up? Or should I just go out and get a new speedo sensor and see if that clears the code and fixes the problem
  • Replies 17
  • Views 2.4k
Basically P0500 code is from the fact off rear tire spins. The ABS has a hard time dealing with front half creeping out say 20 MPH and the rear is spinning faster. ABS can understand it so POOF P0500.
So is it even necessary to do any more trouble shooting, especially since it only pops while I'm waiting to start the engine? Is there any point in replacing speedo sensor?
From what I've seen on the speed checkers around town, the speedo seems right on. The hypertech is set for the larger tires so it's 'fixed' the speedo.
Does the 3-4 gear thing sound like an issue? Or one related to this?
I am curious by what you mean by it only pops while waiting to start the truck? The check engine light always comes on when starting the engine code or no codes. It is just part of the normal starting process.
As far as the tranny, it is out of my league.
I mean, typically what I've always seen was, turn key, WTS comes up along with all other dash lights, then eventually they all extinguish. Well that's what's happening except the CEL still stays on until I turn the key and start the truck, then the CEL is gone. Unless I'm remembering things wrong, but I didn't think the CEL would stay on until the engine was cranked. I thought it would go out with all the other dash lights if there were no codes.
I am pretty sure the CEL stays on until you start the engine. Mine is stuck on right now  to an apps issue. I am sure someone else can confirm or correct me on that.
Ah ok, well if it's supposed to stay on and it's only throwing the code during the times it's supposed tobe on, I'm not going to worry about it.
What I am trying to say is if you have code set it is there. The cel just comes on at key on as a system check, not necessarily because you have an issue. Some codes will not trip the CEL, most will. The ones that do trip the CEL will cause it to stay on after engine start, like my apps code, P222. Just because you see the CEL at start does not mean you have a problem. Dont over think it.
Yea I'm not trying to over think it for sure. I was just confused to whether it was a legitimately thrown code since it only shows the code before the engines started, then once started, the scan gauge will say it's free of codes.
Just so I understand. You get in your truck, turn the key on, scan for codes and the p500 is there. Then you start the truck, scan for codes and it is gone. Maybe I am overthinking.
Yup! That's exactly the way it's happening. Seems weird though right? That's why I was like :think:
Typically error codes are held for 40 warm up cycles before being erased. So P0500 should not just vanish by starting the truck. Then reappear on the next key on. That's got me thinking there is an issue maybe in the ABS computer.
Alright will do. For now, it doesn't seem to be causing issues, it was just something I noticed when scanning the truck at start up. Maybe it just hasn't had enough key cycles to clear itself and it will go away soon enough? :shrug:
I'll update as necessary
Hey Mike, saw this pic you posted in the article regarding the 0500 code
cab-fuses.jpg.de0222dce3fa7c1fce5adc5519
Should I check that fuse? Or pull it and that would reset the CEL that's being thrown? Was just trying to figure out what the pic was for in relation to the write up.
