- Replies 17
- Views 2.8k
notlimah 8 posts
Mopar1973Man 5 posts
dripley 4 posts
So from my research I've done so far, the 1693 code is just a code thrown, letting you know that there is a code present on one of the other computers right?
The 0500 code is a speed sensor and ABS issue, short version, the pcm(?) can't tell why or thinks that front and rear wheels are spinning at different speeds. The CEL only shows up when my key is turned on and the WTS light is on. Once the engine is running, the CEL is not back lit and the truck seems to run fine. Occasionally, I'll have first gear run a little longer then it seems it should, and I have a weird lock up thing happen in between 3rd lock up and 4th. I can expand on those if need be.
Other possible factors to cause this are the hypertech tuner that the PO had installed. I turned off the tune but did let it correct the speedo for the bigger tires. Could that be the reason its throwing the code? And why it's only showing the code during start up? Or should I just go out and get a new speedo sensor and see if that clears the code and fixes the problem
