Sticking clutch pedal
- Replies 100
- Views 19.6k
leathermaneod 43 posts
KATOOM 22 posts
dripley 18 posts
Mopar1973Man 10 posts
On a positive note for you, I've experienced a sticky clutch pedal two times. The story I just told was the second time. The first time was with the stock clutch and the OEM hydraulics. The clu
i experienced some of that with my Valair. Installed a SB on the same hydros and no issues. i dont think my problem was in the hydros. I think either my throw out bearing was binding or the clutch dis
I ran into this very same "sticky" clutch pedal feel about 5000 miles after installing my SB clutch. I did everything as I've always done on any clutch job, and was feeling like the problem was the h
Hi all,
So I have a new Valair single disc clutch with all new components, and new OE hydros from Napa. I have about 1000 miles on the hydros and 550 on the clutch. Today I noticed that sometimes, as I'm slowly letting up on the clutch pedal, it feels like it is sticking or binding kind of. It is only minor and only when I let the pedal out very slowly, which I normally do, and even then its not all the time. Its like it will just kind of hang up slightly then let go and release more quickly than I want it to. I am sure the clutch and components are installed correctly as I and my dad did it together and we are both pretty competent in this area. We also had the help of a friend who is a lifelong mechanic. I checked the FSM and didn't find too much except to grease the pedal pivot point. But in the case of binding, it says to replace the hydros. Since they are new maybe I could grease the pushrod? How would I do that? Just smear some synthetic grease on the pushrod and work it in and out? Has anyone else ever experienced this and or found a solution or have any other ideas?
Edited by leathermaneod
