I can't decide on which governor solenoid to get, the upgraded borgwarner or the GM upgrade. Who's running what?
  • Replies 10
  • Views 1.9k
  • The GM conversion is no better than the Borg Warner HD, but it is 3x as expensive. The GM conversion uses a late-model 4L60E  pressure control solenoid, which often become troublesome when they get up
    I would like to suggest that you get in contact with @Dynamic on the site he's our on site automatic trans guru.
I have the GM upgrade, but I would honestly just go Borgwarner there wasn't a big difference.
What about transducer? Oem or bd upgrade?
Right now I'm really wishing I would have bought a Firepunk instead of this pile of crap
2 hours ago, Me78569 said:
Understand that.
What are your issues?
I had another thread called trans problems
Edited by Jbolduc
The GM unit uses the upgraded borg warner solenoid. So either way you get the best solenoid, borg warner. The GM unit comes with a billet mount and I'm not sure what else that entails. That BD transducer is new. I haven't run across anyone using it yet.
I ended up going with these
The GM conversion is no better than the Borg Warner HD, but it is 3x as expensive. The GM conversion uses a late-model 4L60E  pressure control solenoid, which often become troublesome when they get up there in mileage.I build a lot of 4L60E's that are on my bench because of this solenoid...
The BD kit (TCS also sells it) simply uses an early metal transducer (which tend to be a bit more robust) and supply a small harness that converts the wiring to work with the late-model PCM. I have never used one, so I don't know the specifics on their little wire harness.
I use and highly recommend the Borg Warner HD and an OEM or Borg Warner transducer...
Those are the ones... Decent price, too. We sell them for a couple of bucks cheaper, but this is a good price, too.
