- Replies 16
- Views 9.9k
toesovernoes 9 posts
Mopar1973Man 5 posts
dripley 1 post
notlimah 1 post
Hello to the good people of mopar1973man.com! I am very new to this site as far as having a account but have been a avid "user" for some time now. I figured it may be time to settle in after the site change. Looking forward to helping where i can and learning a few things aswel!
Anyways, on to whats fun and exciting Please allow me to unravel my situation. I have a 1998.5 Dodge ram 2500 5spd 4x4 (vp44, vin 6) that is throwing one ecu code. P0123. I have read the write up on mopar1973man.com regarding this code. The resulting symptoms consisted of dead pedal, intermitent throttle response, the truck reving on its own only when i touch the throttle. I have scoured the internet, service manuals and shops in search of any help or advice as to why this code is appearing. Apps and ecu are what i hear usually. In pursuit of finding a solution i removed the engine wiring harness, ecu, inspected every wire and connector and checked each wire for resistance. I found no resistance. Cleaned each connection, ground and reinstalled the harness. Then set the apps voltage via the adjustment screw on the new apps sensor i installed. Connected the batteries, set the apps via throttle pedal and fired up the truck and it ran great. No problems or codes at all for a week. I then parked the truck for approximatly a month. Today i started the truck and experienced the exact same symptoms as before. My first instinct is to check the harness again but would like to hear what you good folks have to say. Has anyone else encountered this issue before?
Thanks, James
