Purchasing my first Travel Trailer need advice
Alright guys I am looking to purchase my first ever travel trailer :hyper:. So I have looked at Jayco's which I like but then I looked at a Keystone Springdale 240 and I really like this setup. easy to tow I didnt want anything to long since it is my first TT.  http://www.johnniewalkerrv.com/rv/las+vegas+nv/keystone+traveltrailer/7650/keystone+springdale+240bh
the price is 24,000 and now there is a sale pending. So I did a little more research and found a Coleman CTS244BHWE on sale for 17,995
http://www.lasvegasrv.com/new-travel-trailer-rvs/2016-coleman-coleman-cts244bhwe-1243015
 I like both models but the coleman is more in my price range right now not to say I couldnt get the springdale its just I do not know how often I would take it out to get my monies worth per say. The other issue is the coleman trailers are offered at camping world which do not have very good reviews. The other Rv center does not know when they will get another Springdale in. So after all that does anyone have any thoughts on the coleman trailers? Any advice or guidance at buying any trailer will be much appreciated.
Edited by CSM
  • Replies 76
  • Views 16.1k
  • The guy did an awesome job with the weight distribution hitch install i have bags but no air in them and it does not even look like I am hauling anything.
  • Killer223
    Killer223
    yeah until we get more info what he's  lookin for it's hard to say. i know mine loaded is 13200 last time across the CAT scales. but i have toy hauler 5er though and 140 gallons of water, 50 gallons g
  • Killer223
    Killer223
    remember, 80% of them just sit. and are used 4-5 times. then once or twice a year. nothing wrong with used. always replace teh bed with a pillow top. the couch is not big deal. Whats the intended
test drive it in the driveway. camp out for a weekend in the driveway or back yard. You might learn alot about what you need and or are missing. what you don't need. etc.
and no cheating and going into the house.
Actually, I suggest the same thing but I highly suggest the cheating and going to the house for the things you forgot. Then I suggest buying another set of whatever for the RV. We are now down to just packing clothes and electronics. Most of the other stuff is already packed in the RV. So saying we are going to leave is just a few hours of packing and straightening out around the house and locking up. We normally don't bother with food we pick that up on the way usually hitting a larger city store and getting something we normally can't have.
As for the RV I highly suggest doing it without hook ups that way you understand the capacity of water, holding tanks, and power. You learn extremely fast what you can and can't do.
Well I brought her home Monday I got it in the spot but not without a battle scar I had to re- position and instead of taking my time I flew out like a moron and caught the brick wall.
But after 30 min and some frustration I got it
That's called character and experience.  It is a great looking trailer.
Thanks! yes you are right but I wish it happened after a few months and a couple of camping trips. But I am excited to get out and go camping. :thumbup2:
URL]56da8611c46e0_dont_copy(15).jpg.052c30c256da85f1e9a16_dont_copy(12).jpg.7030e7f656da85e628120_dont_copy(11).jpg.56c6028a
When backing up into a tight confined area, especially at night I use 2 way radios.  I put one on the dash and have my spotter talk me in with the other.  Think of it, the back end of that trailer is 40' from where your sitting.
OK guys now I need a little advice. My awning light on my trailer stopped working the remote I have use to turn it on the switch never did for some reason. So I plugged my trailer in and I was checking everything and noticed the light didnt work I turned the switch on it blew a fuse. I whipped out the volt meter and it shows a little over 13 volts going out when the switch is on and 16 amps. The fuse that the dealer put in it was a 15 amp. When we picked up the trailer they said they had to replace a fuse which is the same fuse that is blowing now. So my question is do I put a bigger fuse just to check it out? Is the LED strip bad now? The reason I am asking is I am leaving friday to go on a trip. I have been trying to leave work early to take it to the dealer so they can look at it with no luck. I was hoping this could be an easy fix that I could take care of. Thanks for any the help.
I would say the LED strip is bad and drawing to much amperage. 16 Amp x 12 Volts = 192 Watts. That's like my pair of aircraft landing lights on the front of my truck 100w a piece...
OK Thank you for the help. It just bites that it has gone bad when I have only turned it on maybe 5 times since picking it up. But oh well at least its still under warranty I guess.
Never, ever put a bigger fuse in to test for a short circuit. The wires will heat up and burn thing around them before the fuse will blow.  I had to fix the aftermath of an electrical fire because someone put a 16 amp fuse where an 8 amp went.
I agree it was a thought but I knew the possible ramifications if I did so I did the right thing. When I get back from this trip I will take it in to get fixed.
As a kid I used to roll up a tin foil gum wrapper and shove it in the fuze block :doh:.  I never had to buy spare fuzes after that. :wink:
I did that too until the day the main power lead coming in the cab of my 1973 Charger got over loaded from a bad blower motor and I used a bigger fuse with a gum wrapper. Needless to say the magic smoke can out of the wires under the dash and left me stuck on I84. I did get going again my Fluke meter wires did the trick till I got home in California again.
