Truck loses power and wires are cut
- Replies 75
- Views 12.6k
99 confused 32 posts
dripley 16 posts
Me78569 10 posts
Mopar1973Man 8 posts
Ok here is the most recent news on our dodge. We received and placed the draw straw, it fixed some of the issues. The most recent fix was the injection pump, it took us a while to save up, but it is n
Ok with alot of help we have figured out that the lift pump is going bad and with the previous owners the pump went out so that caused a lot of issues for us to figure out. We have came to the conclus
Lift pump leads... Look at pins 15 & 35 on the ECM.
We recently purchased a 98.5 laramie slt, and we have fixed the boost sensor the tps and replaced the filter, we are now looking to replace the lift pump. We rented a fuel pressure gauge and hooked it up and we got idle pressure of 19 to 20 and reed pressure of 10 to 11, we have been told that it should run a constant pressure of at least 14 to 16. When we removed it we noticed some wires were cut, yellow with a white tracer going into the ecm and it is both wires. We have done a lot to this truck and we are at a loss, when we rev it up the pressure drops and the engine starts to run flat has no power. Please help us.
