- Replies 25
- Views 7k
dodgedieselnewbie 10 posts
Me78569 7 posts
CSM 6 posts
notlimah 1 post
Don't stack timing. Read the back of the smarty and don't use the +timing tunes with the edge. The smarty adds a minimum of 60hp on a stock truck regardless of the level. The higher the number the
Remember comparing the edge and smarty is apples to oranges. Boost / EGT's will be noticeably lower with the smarty as it is not a wiretap b
Dude I had a mini panic attack for you! I had to go back and watch the video in a higher res because I thought your fuel pressure was way low, especially for your mods! But, you have a 0-40psi gauge s
I borrowed a friends Smarty S03 to see if I like it. I don't think I will be comfortable enough to run the Edge and Smarty at the same time. If I do get the nerve.. I know enough not to run the Smarty on advanced timing settings. Any advice on what settings to try? There only appears to be one setting with boost fooling. Does this mean that any of the other settings.. that I should not be able to obtain boost levels over 20? I ask because I already tried the fuel saver mode for like 5 minutes and got my boost gauge to 30 and didn't think that could happen.
