- Replies 11
- Views 7.2k
leathermaneod 5 posts
Mopar1973Man 2 posts
Haggar 2 posts
Buzzinhalfdozen 2 posts
Popular Days
Leatherman, Read through this. It is one of the most concise description and diagnosis list I have seen.http://www.brakeandfrontend.com/operation-diagnosis-and-repair-of-hydro-boost-power-assist
Glad you had time to peruse it! I agree with you, the way I read it, yours isn't "broken". lol Maybe a bit of lube on the pivot? See if that changes the slow return. I will try and chec
Hi all,
So I've had a slow to return brake pedal since I bought the truck a year ago, but I was hoping after a power steering and brake fluid flush it would be better. Well I finally got around to flushing them and so far it's not much if any better. It takes a solid 3 seconds for the pedal to return when the truck is warm and even more when cold. I even took apart and cleaned the valve on the high pressure power steering line at the reservoir. And I used almost 4 qts of ps fluid to do the flush. Now we did only pump the brake twice lightly while doing the ps flush, but it spewed almost a qt of ps fluid just from that so we figured that was good for the hydroboost side of things. Anyway the brakes work great, I'm just wondering if there is anything else I can or should do to help this slow return besides replacing or rebuilding the hydroboost. Another ps and hydroboost flush maybe? I don't want to tackle rebuilding the hydroboost until it's really necessary and right now this isn't a major problem. My vacuum pump and ps pump need resealed first to fix my oil leak lol.
thanks in advance guys!
