- Replies 101
- Views 11.5k
leathermaneod 47 posts
Mopar1973Man 22 posts
Me78569 21 posts
dodgedieselnewbie 8 posts
Mpg is 99% controlled by your right foot.
yep both oval the 01 sensor is the commonly used one. Typically if you buy a 02 sensor you actually get an 01 sensor with a pigtail.
Sometimes the only answer is MOOOREE POWERRR!!!!
Hi all,
ive been trying for a few months now to get my scanguage calibrated. I followed all instructions to the letter, as far as I can tell, but many fill ups later I was still having to adjust the offset percentage by around 100%. I tried messing with diesel a and diesel b today on the drive to work to see if it changed the gph, but it was really hard to tell. However, most of the time it seems like the gph reading is way lower than it should be. Even beyond the typical 0 at idle. Is it possible that my truck is incorrectly reporting fuel consumption? Is there any way to test or calibrate that? Anyone have any idea what I'm doing wrong? I love the scanguage for its other features but I would really like to be able to see accurate mpg data....
