Electrical guidance.. adding lights
- Replies 8
- Views 2.9k
Mopar1973Man 2 posts
IBMobile 2 posts
notlimah 2 posts
Wild and Free 1 post
Popular Days
I don't have any wires hooked to the batteries of any of my accessories. Just a few hook to the PDC (AirDog, Fog lamps, and Cab Accessories). I've got
Just another thing to throw out there on relays. I say this because I chased similar issues on a couple different rigs over the years where someone wired in accessories like Mike shows in his diagrams
In Mike's diagram terminal 86 of both relays are used to ground them. The black wires join together then a switch is shown. After the switch there is the symbol for ground. The ground can be just a
I'm not good at all when it comes to electrical. I would like to wire up some fog lights, rear back up lights, third brake light on my topper and moon visor lighting.
I'd like to know if I can just wire the third brake light into the tail light or hitch wiring without a relay? It's LED I believe...
The moon visor lighting... can I just wire it into the headlight switch somehow.. without relay?
I already have fog lights in the factory location in the bumper but are not factory wired. The previous owner installed with relay and toggle. I want to run another set of fog lights under the bumper on a toggle. I have wiring and relay that came with it. I will basically look at the other fog lights and duplicate how it is run.
I want to install additional reverse/spot lights and have it on a toggle and not come on with the reverse lights. I will use these when needed.. like hooking up to camper in the dark. I will need a relay and wiring for this. Having never bought a relay before... where do I get one and how do I choose one?
My battery already has multiple wires running to it and don't want to put anymore on it. In fact... I'd like to reduce them. Can I put a junction somewhere to accommodate all extra positive wiring? Same question for relays? Already have one just sitting behind the battery for existing fogs.
Thanks!!!
