UDC Pro is here for 03-07 5.9's!!!
- Replies 15
- Views 9k
I did my first towing with UDC Pro this weekend... and WOW. The only really big difference to the power portion of my tuning is that the pilot is removed at the rpms/loads I pull hills at
300 mile tow yesterday. Much of the drive was at 70-72 and I really like how it drives. No real change in mileage over the previous trip on this road, but the truck is much smoother and much better ov
I have around 4K miles now with pro and it's been great, but still now towing... been an odd year for that but I should hook up to the trailer soon. The biggest thing I have done is with
UDC Pro 0.0.0.12 was released last Wednesday and I've been re-tuneing my truck.
I did my last tune revision at the end of last years tow season and have been very very please with how it preforms so I really have done too much with the big tables, timing, rail pressure, and duration.
I started off looking at the fuel limiters, of which there are many. Since my truck is used as a towing/hunting/camping truck I am not going crazy with the fuel. I was able to improve spooling and mid rpm fueling but utilizes the stock limiters to have a smoke free experience. I can now put my foot on the floor at 1500 rpms and not have any black out the tail pipe, yet it still lights the turbo and takes off as fast as before.
After a few drives it feels like I have all my power thou I won't know until I hook up the trailer and head into the hills. Since my duration table hasn't changed and my timing is the same it should be the same... just depends on how the limiters are setup.
Then it was time to address the pilot injection event. I had already completely killed the post even in my first tune. The pilot on the 04.5-07 and the 03-04 is HUGELY different. The DEMO and licensed version of UDC Pro have all the stock files from 03-16 in it which makes comparing easy. The 03-04 uses a smaller pilot with less timing and even shuts it off at higher rpms and loads. Before even looking at the 03-04 stock tunes my intent was to kill it above 2400 rpms from 0%-100% and above 2200 rpms from around 40%-100% load.
Because I have the 03-04 piston I studied the stock stuff for 03-04 pretty hard and it gave me about an 80% solution. I have setup my pilot to be much, much, smaller and not have the huge timing advance that the 04.5-07 did, as much as 57° ahead of the main event! WOT at 2900 rpms the pilot was firing about 58° BTDC! The 03-04 only uses about 4-5mm3 per pilot shot while the 04.5-07 uses up to 15mm3.
I was able to cut my pilot WAY down and bring the timing back a bit on it too, as well as drop it at the rpms I mentioned above. The transition from pilot to no pilot is very smooth and quiet, and the reduced pilot in normal driving rpms is an improvement as well.
I have noticed my load is a little higher at idle now but I am guessing that's from a smaller pilot and thus a bigger main event.
It's also easy to tell there was a lot more emissions restraints on the 04.5-07 engines than the 03-04. The 03-04 only has 2 altitude adjust tables while the 04.5-07 has 5! Aparantly the EPA was worried about emissions while towing at 18K feet... 90% of owners will only ever operate in tables 0 and 1 and the rest will likely never get to 3-4. Tables 0 and 1 are both for the same elevation, up to around 10K feet, but have different tables and triggers based on intake air temp. This is handy as you can mess with timing with a very high IAT. The tables start to blend at 90° and fully into table 1 at 180°.
I was also able to drop my CC engage speed to 20! I have always hated the 35mph minimum from Dodge.
As for licensing dongles only 1 is needed per tuner, not per VIN. So if you have a MAIN or VIN dongle you can get a Pro tune from a tuner with no additional dongles. If you want to do Pro yourself you will need a Pro license dongle.
So there it is in a nutshell. There is also some real time tuning capabilities that I haven't messed with yet, but plan to purchase the hardware to do so shortly.
