Ham radio operators
Any ham operators here? if so list what you have and callsign.
yaesu ft8800 in the car
yaesu ft7900 in the truck
stryker 955hpc 10m ham in truck
a few baofeng uv-5r
connect system CS750 DMR-MARC
my callsign KE0AGE
Edited by CUMMINSDIESELPWR
  • Replies 30
  • Views 7.4k
  • I know it must be hard to concentrate on driving when you are hearing everything the space station is broadcasting....
  • CUMMINSDIESELPWR
    CUMMINSDIESELPWR
    final product "canned ham"   (No subject)         r r
  • CUMMINSDIESELPWR
    CUMMINSDIESELPWR
    yeah canned ham was my idea hahaha  and its my hand holding the side latch   the radio itself draws .5 amp while not transmitting and 9a transmitting @50w. i have 18ah total of battery and
I've been looking at getting a ham radio for the truck. You should post a pic of your setups too so for those of us who don't have setups can scheme/dream!
this is the center cubby i made for the radios and extra storage, the ft7900 sits on the inside of the front wall and the stryker site on outside of the front wall. the ft7900 has a detachea le faceplate that is mounted on the dash trim along with 3 phone mounts i use for various running apps while driving. ill get pics today and post them
i ran the two power feeds under the shifter housing so its clean
my setup in the truck, the dash mounted phone and ham head units will look better and level when i get a 1"x2" and trim it to the contour of the trim ring then mount everything back onto the flat surface (coming soon)
the old phones have full functionality other than no cell service. i can still do anything on them with a wifi connection. i can set one up as a dashcam, clinometer, moving map, speedo, ham data referencing, anything you can think of. being they are iphones i can send pics and vid to my main phone that has cell service and post online.
2 hours ago, notlimah said:
Man you got a lot going on in there!
lmao add storm chasing to it...
it really isnt that bad. most of the time im stationary when using all of it
when driving the phones are reference info, the radio is just pick up the mic and talk, im not really distracted
i was able to get a used dash trim in perfect condition for the price of a case of soda, i reorganized the positions of the phones and took the time to shape the brackets so no need for any wood which was a PITA to shape...
basically same setup just the far right phone is now under the radio on the lip of the dash trim. works out real good too
11m CB was open for a few hours this afternoon and i was skipping all the way to australia from wisconsin. we could talk clearly!!. i spoke with a few people in maine as well along with about 10 other states.
49 minutes ago, notlimah said:
Man this makes me want to get a HAM even more!
this was on regular cb no license required. get a cb radio with upper and lower sideband capability, install and tune the antenna and you are in like flint!
I remember the days of CB's... Now where I live it nearly impossible to transmit out of the valley floor. North end of Riggins, ID looking north as US95 travels the river.
12963452_1102105099810273_53198253807940
after researching i picked up my dedicated handheld.
FT1xdr yaesu
I was going to for search and rescue but the class never happened and fell through. The electronics part I could pass fairly easy I've already done the sample test once long ago. The rest of the test well I need to bone up on...
So that idea goes out the window. :rolleyes:
I want to do it with a friend about 3 years ago being we tend to run together quite a bit in the fire dept and search and rescue. All that changed when he moving to Washington.
