- Replies 9
- Views 5.3k
Wild and Free 2 posts
Explosives87 2 posts
JOHNFAK 1 post
Dieselfuture 1 post
If your going to do it ...... 3rd gen leaves with perch relocation Or softer if you don't need to tow
Many ways to go but what ever you choose do both sides the same. The only way I would do just one side is if I replaced the whole spring pack with an OEM pack. Cheapest way would be to have the spring
I walk to my truck the other day and found that one of my rear leafs on the was missing a 4 inch piece out of it. I am looking for opinions on which way to go. Rock auto as new one anywhere from 150-250 a side, the local spring shop said that they would replace the broken spring and the same spring on the other side along with re curving them for 600. Or I could have local shop, deaver, or atlas spring build me a set that would get rid of the factory block which would cost me around 1200-1500. I would like to know as anyone run leaf that have got rid of the factory leafs and put in after market leafs. Along with when you replaced the leafs did you notice any difference in ride, how the truck handled or lost load capacity?
