- Replies 10
- Views 3.9k
Dieselfuture 5 posts
greed 3 posts
dobienut 1 post
dripley 1 post
I've only checked it one time with an IR thermometer. I don't remember what the temp was. I was towing a 12k fifth wheel over mountain passes. I don't remember being alarmed. I'm about due for a lube
Did a clutch swap in my NV5600 and lost some of the fluid. I just changed the fluid last spring so would just like to add to it to get the proper amount rather than draining it out and putting new in. (Fluid still looks clear) No idea how much I lost so don't know how much to put back in. Top it off until it comes up over the gears be a stopping point or is that too much? I should add I know theres the plug on the side to check, but I cant remember how far up past the plug it went last time I put the extra bottle in..thats why I ask the question
thanks
Edited by dobienut
