Braking issues, need help asap.
- Replies 19
- Views 3.9k
The_Hammer 11 posts
Mopar1973Man 3 posts
Me78569 3 posts
Buzzinhalfdozen 2 posts
Popular Days
When it rains it pours. Sounds like it's time to start over and just replace all the vacuum lines.
Cold hearted humor I know but it was too easy to pass up. Best of luck with the house and vehicle repairs.
Well the pump threads are 12mm 1.25 pitch, something no one around here has. I'm going to try brazing the old one up and ordering something. If worse comes to worse I'll get a seal kit, pull the pump,
My brakes just started acting up, the pedal gets hard and can barely stop. I have vacuum brakes and not hydroboost. I pulled the large vacuum line out of the booster to inspect it and when I did you could hear it suck air. This was after the truck had been sitting for 15 minutes or so which means I don't have a vacuum leak.
I have no fluid leaks anywhere and the master cylinder is still full. Only thing I can think of is the booster just took a dump.
